Pièces
Aucune pièce nécessaire.
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Ajouter un commentaire
Remove the screw on each side of the device using a Phillips head screwdriver.
  • Remove the screw on each side of the device using a Phillips head screwdriver.
  • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
  • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  • Once the back cover has been removed the battery will be visible.
  • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  • Once the battery has been removed you can see the motherboard.
  • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
  • The USB connector can now be taken off of the device.
  • Using the philips screwdriver, remove the two screws on the mother board.
  • Place the pry tool in-between the front cover and mother board.
  • Gently separate the front cover.
  • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  • CAUTION: Do not rip the electric ribbon from the mother board.
  • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  • Remove the 3 screws located around the motherboard. 2 screws are located on the left side and1 screw is located on the right side.
  • NOTE:The orientation of the second picture is screen side down!
  • The motherboard should be loose from the middle casing.
  • Gently pull the motherboard away from the middle casing
  • The device should now be in multiple parts.
Dylan Peters
Membre depuis le 18/10/2013
404 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 14-8, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 280
