Aller au contenu principal
Samsung TFT Color YP-T7J The Battery Replacement
Ce dont vous avez besoin
  1. Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: étape 1, image 1 de 2 Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: étape 1, image 2 de 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Battery Replacement: étape 2, image 1 de 2 Samsung TFT Color YP-T7J The Battery Replacement: étape 2, image 2 de 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Battery Replacement: étape 3, image 1 de 3 Samsung TFT Color YP-T7J The Battery Replacement: étape 3, image 2 de 3 Samsung TFT Color YP-T7J The Battery Replacement: étape 3, image 3 de 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Battery Replacement, The Battery: étape 4, image 1 de 2 Samsung TFT Color YP-T7J The Battery Replacement, The Battery: étape 4, image 2 de 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Battery Replacement: étape 5, image 1 de 2 Samsung TFT Color YP-T7J The Battery Replacement: étape 5, image 2 de 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
Dylan Peters
Membre depuis le 10/18/13
409 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 14-8, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 membres
7 tutoriels rédigés
Un commentaire
Nice instructions. Any idea where I can purchase a new battery that will fit?
grgermain - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 16
Total : 1,860
