Introduction
If your Samsung TL220 is rattling from the inside of the camera, use this guide to replace the battery spring and hold the camera battery in place.
The spring inside the camera is responsible for holding the battery in place. If the spring got loose or no longer supports the battery. It can cause damage to the inside of the camera.
Make sure the camera is completely turned off before starting.
Ce dont vous avez besoin
Begin by unscrewing all seven 4 mm phillip's screws located on the outside of the camera.
Using the plastic opening tool carefully pry open the camera, lifting the back casing off.
Once the orange film strips have been released from the connectors, unscrew the Phillips 4 mm silver screw which holds down the top of the camera's frame.
With your fingers gently push up the camera's top frame. Once the camera's top frame is off you can than gently remove the camera's front casing off, as well.
2 autres ont terminé cette réparation.
