Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front. From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it. There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it. There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Remove the cover from the device.
    • Remove the cover from the device.
3 autre(s) ont terminé cette réparation.
Breanna Ainsworth
Membre depuis le 30/01/2018
258 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S2-G1, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 107
