Aller au contenu principal
Samsung UBD-M8500 Wi-Fi Module Replacement
Ce dont vous avez besoin
  1. Samsung UBD-M8500 Wi-Fi Module Replacement, Outer Shell: étape 1, image 1 de 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Wi-Fi Module Replacement: étape 2, image 1 de 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Wi-Fi Module Replacement: étape 3, image 1 de 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Wi-Fi Module Replacement: étape 4, image 1 de 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Wi-Fi Module Replacement, Wi-Fi Module: étape 5, image 1 de 1
    • Looking at the device with the cover removed you should see a black piece with a green sticker on it, that is the Wi-Fi module.
  6. Samsung UBD-M8500 Wi-Fi Module Replacement: étape 6, image 1 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: étape 6, image 2 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: étape 6, image 3 de 3
    • Pull the Wi-Fi module's connector directly out of its motherboard connection.
  7. Samsung UBD-M8500 Wi-Fi Module Replacement: étape 7, image 1 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: étape 7, image 2 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: étape 7, image 3 de 3
    • Remove the four screws from the Wi-Fi module using the Phillips #1 screwdriver.
    • Be mindful of the two hidden screws in the gaps of the black plastic piece.
Ligne d'arrivée
madison mathis
Membre depuis le 09/15/23
357 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 48
