Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Slide the back cover forward toward the top of the device with your thumb.
    • Slide the back cover forward toward the top of the device with your thumb.
  2. The back cover is now separated from the device.
    • The back cover is now separated from the device.
  3. Apply a fingernail or a plastic opening tool to the base of the battery.
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  5. Lift up gently.  The battery should come up and out.
    • Lift up gently. The battery should come up and out.
  6. The battery is now removed from the device.
    • The battery is now removed from the device.
  7. Remove the two black .265" screws at the base of the device.
    • Remove the two black .265" screws at the base of the device.
  8. Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  9. Slide the rear case cover toward the top of the device with your thumb to release it.
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  10. The rear case cover can now be separated from the device.
    • The rear case cover can now be separated from the device.
Nicolas Coffey
Membre depuis le 27/01/2012
43 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 742
