Aller au contenu principal
Sandisk Sansa m230 Series mp3 player Microphone Replacement
Ce dont vous avez besoin
  1. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Sandisk Sansa m230 Series mp3 player Teardown: étape 1, image 1 de 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 2, image 1 de 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 3, image 1 de 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 4, image 1 de 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 5, image 1 de 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 6, image 1 de 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Microphone: étape 7, image 1 de 1
    • Locate microphone on motherboard.
  8. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 8, image 1 de 1
    • Find where microphone is connected to motherboard via solder.
  9. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 9, image 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 9, image 2 de 2
    • Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 10, image 1 de 1
    • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
    • When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  11. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 11, image 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 11, image 2 de 2
    • Remove the faulty microphone as you heat and melt the soldering points.
  12. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 12, image 1 de 1
    • Replace the faulty microphone with a new one in working order.
  13. Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 13, image 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: étape 13, image 2 de 2
    • With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
    • Give the new solder time to cool and harden.
James Thorne
Membre depuis le 11/05/13
638 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 473
