Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. Lift off the metal plate by pulling it towards you.
    • Lift off the metal plate by pulling it towards you.
  4. Identify the belt and brush roller.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  5. Slide the belt off of the circular knob.
    • Slide the belt off of the circular knob.
  6. Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
    • Pull brush roller out and detach the belt off the brush roller.
Caycie Pascual
Membre depuis le 26/09/2012
1 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 16-58, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 879
