Aller au contenu principal
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: étape 1, image 1 de 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 2, image 1 de 1
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 3, image 1 de 1
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 4, image 1 de 1
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 5, image 1 de 1
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 6, image 1 de 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: étape 6, image 2 de 2
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Caycie Pascual
Membre depuis le 09/26/12
1 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 16-58, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 24
Total : 2,814
