1. Before disassembling the device, make sure it is powered off.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Using a plastic opening tool, lift the metal backing from the front of the device.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Pull the rear panel off of the Sansa e260R.
    • Pull the rear panel off of the Sansa e260R.
  4. Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  6. Remove the four 1.5mm screws on the inner casing of the device.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  7. Flip the device so that the front is facing you.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  8. Pull the front cover away from the rest of the device. Pull the front cover away from the rest of the device.
    • Pull the front cover away from the rest of the device.
  9. Gently pry the bottom of the black button to remove it from the device. Gently pry the bottom of the black button to remove it from the device.
    • Gently pry the bottom of the black button to remove it from the device.
  10. There are 4 small metal hooks under the white scrolling mechanism. To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  11. Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
5 autre(s) ont terminé cette réparation.
JenniferW
Membre depuis le 31/01/2012
161 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-15, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 membres
5 tutoriels rédigés
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 2,463
