Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to remove or replace the case.
Pièces
Aucune pièce spécifiée.
  1. Place your thumb on the right side of the camera over the battery door.
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Remove and recycle old batteries.
    • Remove and recycle old batteries.
  3. Remove the following six screws using the Phillips #00 screwdriver: Two screws on the left side of the camera. Two screws on the right side of the camera.
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  5. Open the battery slot on the bottom of the camera by sliding the door to the right. Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  6. Insert a spudger in the seam at the bottom of the camera. Gently separate the rear case from the front of the camera. Gently separate the rear case from the front of the camera.
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  7. This step is only needed for the case and logic board replacement
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  8. This step is only needed for the case replacement.
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
Ariana Martinez
Membre depuis le 15/04/2010
50 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 24-24, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,787
