Aller au contenu principal
Sanyo VPC-T850 Battery Replacement
Ce dont vous avez besoin
  1. Sanyo VPC-T850 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: étape 2, image 1 de 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: étape 3, image 1 de 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: étape 4, image 1 de 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
James Robinson
Membre depuis le 10/27/15
459 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membre de l'équipe UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 867
