Aller au contenu principal
Sanyo VPC-X1200 flash replacement
Ce dont vous avez besoin
  1. Sanyo VPC-X1200 flash replacement, Back Case: étape 1, image 1 de 3 Sanyo VPC-X1200 flash replacement, Back Case: étape 1, image 2 de 3 Sanyo VPC-X1200 flash replacement, Back Case: étape 1, image 3 de 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 flash replacement: étape 2, image 1 de 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 flash replacement, LCD Screen: étape 3, image 1 de 2 Sanyo VPC-X1200 flash replacement, LCD Screen: étape 3, image 2 de 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 flash replacement: étape 4, image 1 de 2 Sanyo VPC-X1200 flash replacement: étape 4, image 2 de 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 flash replacement, Button Plate: étape 5, image 1 de 2 Sanyo VPC-X1200 flash replacement, Button Plate: étape 5, image 2 de 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 flash replacement: étape 6, image 1 de 2 Sanyo VPC-X1200 flash replacement: étape 6, image 2 de 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Sanyo VPC-X1200 flash replacement, Lens Unit: étape 7, image 1 de 1
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Sanyo VPC-X1200 flash replacement: étape 8, image 1 de 2 Sanyo VPC-X1200 flash replacement: étape 8, image 2 de 2
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Sanyo VPC-X1200 flash replacement: étape 9, image 1 de 1
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Sanyo VPC-X1200 flash replacement, Flash Lens: étape 10, image 1 de 3 Sanyo VPC-X1200 flash replacement, Flash Lens: étape 10, image 2 de 3 Sanyo VPC-X1200 flash replacement, Flash Lens: étape 10, image 3 de 3
    • Remove 4 screws attached to the exterior silver bezel.
    • Four 3.5mm screws
  11. Sanyo VPC-X1200 flash replacement: étape 11, image 1 de 1
    • Remove round silver bezel from the front of the camera.
  12. Sanyo VPC-X1200 flash replacement: étape 12, image 1 de 1
    • Remove the two screws on the bottom of the front cover.
  13. Sanyo VPC-X1200 flash replacement: étape 13, image 1 de 1
    • Remove tripod mount.
  14. Sanyo VPC-X1200 flash replacement: étape 14, image 1 de 1
    • Carefully lift off the front cover plate of the camera.
  15. Sanyo VPC-X1200 flash replacement: étape 15, image 1 de 1
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
Anthony Giardina
Membre depuis le 04/19/10
20 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 2,122
