Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide helps you to remove and replace the lens unit
Pièces
Aucune pièce spécifiée.
  1. Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Gently lift up the back cover and set aside.
    • Gently lift up the back cover and set aside.
  3. Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector. Be careful not to rip out the ribbon connector.
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  5. To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger. Gently lift ribbon out of the gate and set screen aside.
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  6. There are five screws of three different sizes which need removal. One 4.5mm screw
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  7. Slowly lift metal tray to the right. Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  8. Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  9. Remove the three silver screws. Three 5.5mm screws
    • Remove the three silver screws.
    • Three 5.5mm screws
  10. Lift the lens unit free of the camera.  A spudger can be used to separate the lens unit if necessary.
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
Anthony Giardina
Membre depuis le 19/04/2010
20 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,581
