Ce dont vous avez besoin
Place the monitor face down.
Remove the four 11.5mm screws with a #2 Phillips screwdriver.
Remove the stand by pulling it out.
Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Disconnect the two connectors at the top-left of the power board.
Disconnect the two connectors at the very bottom of the power board (pink wire).
Disconnect the multi-pin connector at the top of the motherboard.
Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
