Aller au contenu principal
Screen Door Closer Replacement
Ce dont vous avez besoin
  1. Screen Door Closer Replacement, Door closer: étape 1, image 1 de 1
    • Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
    • If the pin is under too much tension, open the door about an inch and slide the open clip (metal washer that keeps the screen door open) against the barrel and repeat step 1.
  2. Screen Door Closer Replacement: étape 2, image 1 de 1
    • After removing the pin, the closer barrel can be removed.
  3. Screen Door Closer Replacement: étape 3, image 1 de 1
    • Loosen the screws from the bracket on the screen door to remove the bracket.
  4. Screen Door Closer Replacement: étape 4, image 1 de 1
    • Loosen the screws from the door jamb bracket and remove.
  5. Screen Door Closer Replacement: étape 5, image 1 de 1
    • Attach the new bracket to the door jamb with provided screws.
  6. Screen Door Closer Replacement: étape 6, image 1 de 1
    • Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
  7. Screen Door Closer Replacement: étape 7, image 1 de 1
    • Insert the pin into the closer barrel and the jamb bracket.
  8. Screen Door Closer Replacement: étape 8, image 1 de 1
    • Install new bracket onto screen door. Keep screws slightly loose.
  9. Screen Door Closer Replacement: étape 9, image 1 de 1
    • Slip the other pin into the barrel and the bracket.
  10. Screen Door Closer Replacement: étape 10, image 1 de 1
    • Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
  11. Screen Door Closer Replacement: étape 11, image 1 de 1
    • Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
2 autres ont terminé cette réparation.
Shafaq Hasan
Membre depuis le 10/26/17
122 Réputation
1 tutoriel rédigé
Équipe
DePaul University, Team S1-G10, Dush Fall 2017 Membre de l'équipe DePaul University, Team S1-G10, Dush Fall 2017
DPU-DUSH-F17S1G10
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 99
Total : 9,753
