Aller au contenu principal
Screwdriver Best Practices
  1. Screwdriver Best Practices, Driver Selection: étape 1, image 1 de 2 Screwdriver Best Practices, Driver Selection: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Mako Driver Kit - 64 Precision Bits
    $39.95
    J'achète
    • Different screw heads call for different driver types. Whether it be Phillips, Japanese Industrial Standard (JIS), Pozidrive, Torx, Triwing, or plain old Flathead, use the correct driver for your application.
    • Using a driver that’s “close enough”—such as by turning a Phillips screw with a Flathead driver—can sometimes get you out of a bind, but mostly it’s a recipe for trouble.
    • What’s that, you say? That sounds like a lot of drivers to keep track of? Try using a set of interchangeable bits, like the 64 Bit Kit for electronics repair or the Universal Bit Kit for larger applications.
  2. Screwdriver Best Practices, Size Selection: étape 2, image 1 de 3 Screwdriver Best Practices, Size Selection: étape 2, image 2 de 3 Screwdriver Best Practices, Size Selection: étape 2, image 3 de 3
    • A correctly sized driver should “fill up” the screw head, utilizing both the full depth and width of the socket.
    • Beginners commonly make the mistake of using a driver that’s too small. An undersized driver slips easily, damaging the screw head and making it difficult to turn afterward—even with a correctly-sized driver. This is known as a stripped screw.
    • An oversized driver fits into the screw only shallowly, if at all.
    • When you find a driver that fits about right, compare the next size up as well as the next size down before you proceed.
    • In general, use the largest driver size that fits snugly into the screw.
  3. Screwdriver Best Practices, Proper Use: étape 3, image 1 de 3 Screwdriver Best Practices, Proper Use: étape 3, image 2 de 3 Screwdriver Best Practices, Proper Use: étape 3, image 3 de 3
    • Keep your drivers in good working condition by using them only as designed.
    • Avoid using screwdrivers as improvised pry tools or chisels.
    • Prying with a screwdriver can bend or break the tip, making it useless for turning screws.
    • Chiseling with a driver can deform the tip. A damaged driver like this one no longer fits snugly in the screw head, resulting in slippage (and stripped screws).
    • To avoid stripping screws, only use drivers that are in good condition.
  4. Screwdriver Best Practices: étape 4, image 1 de 3 Screwdriver Best Practices: étape 4, image 2 de 3 Screwdriver Best Practices: étape 4, image 3 de 3
    • Use continuous downward pressure to keep the driver tip in contact with the screw.
    • A limp grip or a lack of pressure will cause the driver to simply slip out of the screw head instead of turning the screw.
  5. Screwdriver Best Practices: étape 5, image 1 de 2 Screwdriver Best Practices: étape 5, image 2 de 2
    • Keep the driver directly in line with the screw, with the shaft directly over the screw head. The driver and screw should be “on-axis,” forming a straight line.
    • Holding the driver at an angle creates a poor fit between the driver and the screw head. Result: slippage and probable damage to the screw.
    • Sometimes the screw itself needs to go into the surface at an angle. Keep the driver positioned correctly relative to the screw, rather than the surface it’s going into.
  6. Screwdriver Best Practices: étape 6, image 1 de 3 Screwdriver Best Practices: étape 6, image 2 de 3 Screwdriver Best Practices: étape 6, image 3 de 3
    • Whenever you install a screw, first turn the screw counter-clockwise (in the “loosey” direction) to “seat” the screw.
    • Turn slowly until you feel the screw level off and sink slightly, then stop.
    • Now it's safe to tighten the screw.
    • A properly installed screw will turn easily until it's fully tight.
    • An improperly threaded screw gets increasingly difficult to tighten—because the misaligned threads are cutting across the threads in the screw hole, causing permanent damage. This is known as "cross-threading."
    • If your screw doesn't tighten easily, back off and carefully re-seat it, and try again.
  7. Screwdriver Best Practices: étape 7, image 1 de 1
    • Finally, use appropriate torque when tightening screws down. A properly fastened screw will be snug, but not so tight that your driver starts to slip.
    • This is largely a matter of feel, so your technique will improve with practice.
    • Smaller screws generally require less torque; over tightening them can damage their threads.
    • Very small screws—such as those used in phones and tablets—require very little tightening force. As soon as you feel resistance, give it another quarter turn or less and then stop.
Ligne d'arrivée
284 autres ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 08/06/13
428 648 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 277 tutoriels rédigés
4 commentaires
Regardless of whether you are a technician or a DIYer I strongly recommend that you buy the best quality screwdriver possible. Quality screwdrivers will last a lifetime or longer. Poor quality screwdrivers will quickly wear out making them useless and will damage the screws.
Quality brands - in no particular order and what I can recall at present - include PB Swiss, CK, Wera, and Snapon.
Alan Liefting - Réponse
Excellent tutorial, Jeff! Thanks for creating this. I’m a 60 year old grandmother, and a widow…finding myself taking on repair projects these days that I never thought I’d ever be doing. But I enjoy tinkering and fixing things, or trying to make something “work better”. So it never hurts to review the basics….some of us missed some details the first time around. Thanks again :-)
jmcglothren - Réponse
I am a newbie to the ifixit community, recently changed the battery on my iPhone 6. I always appreciate the opportunity to review “basic” information on DYI skills and tools to see if I can learn new knowledge, as was the case with Jeff’s tutorial on the use of screwdrivers. :)
Gary Speer - Réponse
Great! Super happy to hear that!! If ever you’d need guidance around here, have questions or suggestions, don’t hesitate to reach out using community@ifixit.com. Right on!
Sandra Hiller -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 111
30 derniers jours : 547
Total : 31,737
