Introduction
This guide details how to replace a malfunctioning fan in the Sega Dreamcast.
Be sure to replace the fan with one corresponding to your Model Number. Refer to the Top Cover Disassembly Guide for instructions on where to find your model number.
Ce dont vous avez besoin
Flip the console over on its back.
Take note of your model number, in case replacement parts are needed.
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
Remove the white fan header by gently pulling it away from from the controller port.
Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
4 autres ont terminé cette réparation.
