Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
A guide to remove the Top Cover of the Sega Dreamcast.
Pièces
Aucune pièce spécifiée.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  5. Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
6 autre(s) ont terminé cette réparation.
wkwong
Membre depuis le 14/11/2009
429 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-1, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 membres
18 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 44
Total : 9,517
