Introduction
Although the Sega Game Gear TV Tuner is long outdated, it’s still a pretty cool retro handheld console attachment. In the 90’s, before the era of digital television, all you needed was a Game Gear with Tuner attached and you had your very first handheld console with the ability to “stream” video. With a A/V input built in you can still use it, with HD antenna attached, to watch television or even do some outrageously silly stuff like play Xbox 1/PS4 using your Sega Game Gear as a TV. Just remember to bring batteries.
Ce dont vous avez besoin
Remove PH1 screw and lift up on the antenna to remove it
Remove 4 PH0 screws
Remove 2 3.8mm gamebit screws
Lift rear tuner shell away from unit
A peek on the inside reveals 2 small retaining clips. Simply apply some pressure on the clips with a needle nose tweezer
Remove the motherboard from the unit
If it makes your repair easier you can separate the two PCBs by gently pulling the ribbon out of its connector. This is a friction fit cable
Flip the PCBs over with the back side facing you.
Remove 1 PH0 screw
Flip the board over again and gently pull the tuning dial assembly out of the pin header socket
2 autres ont terminé cette réparation.
3 commentaires
does anybody know what the ribbon cables pinout is? I would love to know, so I can hook up some video-in to the tv tuner board, since my good guess is, that the upper part is just transporting or converting the signal it gets from its receiver to a mere video-in signal with LandR audio, since you can also hook up video-in to the tv tuner on the jack. and my other wild guess is, that the board the actual receiver is hooked up to splits up the signal into 8-bit chunks the game gear itself can understand. Please feel free to correct me and give more info, i NEED the pinout, since i got no tools at home to check what the ribbon cable actually is cooking.
A small washer fell out of mine when I was taking it apart. Any idea where it goes?
If it's very thin and small circumference it goes between the antenna and swivel. There may be 2 of them.
