Aller au contenu principal
Sega Genesis Flashback Controller Batteries Replacement
Ce dont vous avez besoin
  1. Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: étape 1, image 1 de 2 Sega Genesis Flashback Controller Batteries Replacement, Controller Batteries: étape 1, image 2 de 2
    • Using a Phillips #000 screwdriver, unscrew the single screw located on the battery cover. Remove the battery cover and set it aside.
    • The screw does not detach from the battery cover, so do not attempt to separate them.
  2. Sega Genesis Flashback Controller Batteries Replacement: étape 2, image 1 de 2 Sega Genesis Flashback Controller Batteries Replacement: étape 2, image 2 de 2
    • If batteries are in the battery slots and need to be replaced, then remove the old batteries by pressing them in and compressing the spring until there is enough space to take them out.
    • Insert two fresh batteries into each one of the slots by pushing the indicated negative end of the battery against the spring.
    • All AAA batteries have “+” and “-” symbols on each end of the batteries to denote the positive and negative ends.
2 autres ont terminé cette réparation.
Omar Shorab
Membre depuis le 04/23/18
261 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S24-G12, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 membres
10 tutoriels rédigés
Un commentaire
any idea where i can find a schematic for the contoller board. I just bought one of these second hand and the wireless controller won’t connect to the system. I took it apart and it’s missing a small resistor.
Scott Phaneuf - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 26
Total : 2,687
