Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
We all know that the Sega Genesis brought to us many hours of fun, but, as we get older, the reset button gets older too.
Today, let's lend a hand to our nice friend and replace its reset button!
Pièces
Aucune pièce spécifiée.
  1. Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Flip the Sega Genesis upright.
    • Flip the Sega Genesis upright.
  3. Gently lift the top casing.
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Bend out the LED leads into vertical positions.
    • Bend out the LED leads into vertical positions.
  5. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  6. Slide the LED wire apparatus off the lead pins.
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  7. Separate the main board from the outer case.
    • Separate the main board from the outer case.
  8. Using Philips screwdriver, remove 11 screws securing silver casing.
    • Using Philips screwdriver, remove 11 screws securing silver casing.
  9. Remove silver case.
    • Remove silver case.
  10. Locate reset button on motherboard
    • Locate reset button on motherboard
  11. Place three pieces of 1cm x 1cm masking tape over reset button.
    • Place three pieces of 1cm x 1cm masking tape over reset button.
To reassemble your device, follow these instructions in reverse order. And the most important, be happy!
calvin
Membre depuis le 05/10/2010
198 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-29, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 membres
11 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 77
Total : 13,040
