Aller au contenu principal
Sega Saturn Power Supply Replacement
Ce dont vous avez besoin
  1. Sega Saturn Power Supply Replacement, Battery: étape 1, image 1 de 2 Sega Saturn Power Supply Replacement, Battery: étape 1, image 2 de 2
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
  2. Sega Saturn Power Supply Replacement: étape 2, image 1 de 3 Sega Saturn Power Supply Replacement: étape 2, image 2 de 3 Sega Saturn Power Supply Replacement: étape 2, image 3 de 3
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
  3. Sega Saturn Power Supply Replacement: étape 3, image 1 de 3 Sega Saturn Power Supply Replacement: étape 3, image 2 de 3 Sega Saturn Power Supply Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the ESD safe tweezers to pull the battery out of its slot.
  4. Sega Saturn Power Supply Replacement, Case: étape 4, image 1 de 3 Sega Saturn Power Supply Replacement, Case: étape 4, image 2 de 3 Sega Saturn Power Supply Replacement, Case: étape 4, image 3 de 3
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
  5. Sega Saturn Power Supply Replacement: étape 5, image 1 de 3 Sega Saturn Power Supply Replacement: étape 5, image 2 de 3 Sega Saturn Power Supply Replacement: étape 5, image 3 de 3
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
  6. Sega Saturn Power Supply Replacement, Power Supply: étape 6, image 1 de 2 Sega Saturn Power Supply Replacement, Power Supply: étape 6, image 2 de 2
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
  7. Sega Saturn Power Supply Replacement: étape 7, image 1 de 3 Sega Saturn Power Supply Replacement: étape 7, image 2 de 3 Sega Saturn Power Supply Replacement: étape 7, image 3 de 3
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
  8. Sega Saturn Power Supply Replacement: étape 8, image 1 de 2 Sega Saturn Power Supply Replacement: étape 8, image 2 de 2
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
  9. Sega Saturn Power Supply Replacement: étape 9, image 1 de 3 Sega Saturn Power Supply Replacement: étape 9, image 2 de 3 Sega Saturn Power Supply Replacement: étape 9, image 3 de 3
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
Jan Ulloa
Membre depuis le 10/15/19
630 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
3 membres
18 tutoriels rédigés
1 commentaire de tutoriel
Incomplete. This is "Removal" only. "Replacement" indicates that there is a replacement part. Where is the replacement part? Where do you obtain/purchase it? No description of the replacement part or link to obtain it. Clarify.
BGPhilbin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 30
30 derniers jours : 105
Total : 6,501
