Introduction
If the headphones will not accept a charge from the micro usb cable, the charging port may need to be replaced and the volume dial is soldered onto the circuit board. This process is moderately difficult and may take up to three minutes. The only tool necessary will be the #000 Philips screwdriver.
Ce dont vous avez besoin
After removing the muffs, the speaker cover must be removed by unscrewing 4 3mm Phillips screws using a #000 Phillips screwdriver.
