Aller au contenu principal
Separating Rear Board
Ce dont vous avez besoin
  1. Separating Rear Board, Remove Battery: étape 1, image 1 de 3 Separating Rear Board, Remove Battery: étape 1, image 2 de 3 Separating Rear Board, Remove Battery: étape 1, image 3 de 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. Separating Rear Board, Remove Trigger Buttons: étape 2, image 1 de 2 Separating Rear Board, Remove Trigger Buttons: étape 2, image 2 de 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. Separating Rear Board, Remove Screws: étape 3, image 1 de 2 Separating Rear Board, Remove Screws: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. Separating Rear Board, Unclip Covers: étape 4, image 1 de 3 Separating Rear Board, Unclip Covers: étape 4, image 2 de 3 Separating Rear Board, Unclip Covers: étape 4, image 3 de 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. Separating Rear Board, Separate Covers: étape 5, image 1 de 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. Separating Rear Board, Remove Ribbon Cable: étape 6, image 1 de 3 Separating Rear Board, Remove Ribbon Cable: étape 6, image 2 de 3 Separating Rear Board, Remove Ribbon Cable: étape 6, image 3 de 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. Separating Rear Board, Remove Caps: étape 7, image 1 de 2 Separating Rear Board, Remove Caps: étape 7, image 2 de 2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. Separating Rear Board, Remove Screws: étape 8, image 1 de 3 Separating Rear Board, Remove Screws: étape 8, image 2 de 3 Separating Rear Board, Remove Screws: étape 8, image 3 de 3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. Separating Rear Board, Separate Rear Board: étape 9, image 1 de 3 Separating Rear Board, Separate Rear Board: étape 9, image 2 de 3 Separating Rear Board, Separate Rear Board: étape 9, image 3 de 3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
2 autres ont terminé cette réparation.
Brian W
Membre depuis le 12/21/11
1 692 Réputation
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 11
Total : 538
