Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This repair guide solves any rotation and vibration problems that the fan might have. The track at the bottom of the fan is the main source of rotation and vibration problems. Use the tear-down guide to remove all other components to get to the track.
  1. Use the Philips #2 screwdriver to remove the four 6mm Phillips #0 back screws by unscrewing counterclockwise.
    • Use the Philips #2 screwdriver to remove the four 6mm Phillips #0 back screws by unscrewing counterclockwise.
  2. Pull the front and back cover apart.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Remove the Phillips 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Remove the Phillips 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Remove the screws from the four corners of the circuit board. Remove the circuit board from the top cover.
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. In order to remove the fan blade pliers were used to remove the holding nut. After the holding nut is loose, use the pliers to pull up to remove the nut.
    • In order to remove the fan blade pliers were used to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
  7. Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
  8. Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer. Remove screws by pulling them away from the base.
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
  9. Clean the track, removing any obstructions. Lubricate the track with grease.
    • Clean the track, removing any obstructions.
    • Lubricate the track with grease.
2 autre(s) ont terminé cette réparation.
Queena Phung
Membre depuis le 26/09/2012
111 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-46, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 54
Total : 7,388
