Introduction
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Pièces
Aucune pièce nécessaire.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
Ajouter un commentaire
Pull the front and back cover apart.
  • Pull the front and back cover apart.
  • Be careful not to pull the front cover off completely because it holds the wires.
  • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
  • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
  • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
  • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
  • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Mateo Begue
Membre depuis le 26/09/2012
78 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-46, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 809
