Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Pièces
Aucune pièce spécifiée.
  1. Use the Philips #2 screwdriver to remove the four 6mm Phillips #0 back screws by unscrewing counterclockwise.
    • Use the Philips #2 screwdriver to remove the four 6mm Phillips #0 back screws by unscrewing counterclockwise.
  2. Pull the front and back cover apart.
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Remove the Phillips 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Remove the Phillips 6-mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Remove the screws from the four corners of the circuit board. Remove the circuit board from the top cover.
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
Mateo Begue
Membre depuis le 26/09/2012
102 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-46, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 1,091
