Aller au contenu principal
Introduction
If you are having a problem with your device's Front Belt, Here is a Step by step guide to replace a faulty or broken Front Belt.
Pièces
Aucune pièce spécifiée.
  1. Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit. Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Once the screws are removed pull the front face plate off. This will allow access to the belt and motor. Once the screws are removed pull the front face plate off. This will allow access to the belt and motor. Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Lift the brush roller upwards towards you, and the brush roller should come out along with the belt. Lift the brush roller upwards towards you, and the brush roller should come out along with the belt. Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Remove the belt from the motor mount, and then replace with a new belt. Remove the belt from the motor mount, and then replace with a new belt.
    • Remove the belt from the motor mount, and then replace with a new belt.
Ben Dzugen
Membre depuis le 02/02/2017
374 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 membres
6 tutoriels rédigés
2 commentaires
Nice and simple but where can we purchase the belts?
jmrlachance - Réponse
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 1,594
