Introduction
If your vacuum will not turn on and the power cable/connector is faulty, use this guide to replace the power cable/connector. You will need wire strippers, wire end caps, and the T10 and T20 Torx Screwdrivers. Reassembly requires rewiring.
Ce dont vous avez besoin
Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
Use the T20 screwdriver to remove the two 12 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 17 mm screws by turning counterclockwise.
Use the T20 screwdriver to remove the two 14 mm screws by turning counterclockwise.
To reassemble your device, you must rewire a new power cord, then follow these instructions in reverse order.
6 autres ont terminé cette réparation.
