Aller au contenu principal
Shark IQ AV993 Wheels Replacement
Ce dont vous avez besoin
  1. Shark IQ AV993 Wheels Replacement, Battery: étape 1, image 1 de 1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Wheels Replacement: étape 2, image 1 de 1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Wheels Replacement, Bumper: étape 3, image 1 de 2 Shark IQ AV993 Wheels Replacement, Bumper: étape 3, image 2 de 2
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Wheels Replacement: étape 4, image 1 de 1
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Wheels Replacement: étape 5, image 1 de 1
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
  6. Shark IQ AV993 Wheels Replacement, Wheels: étape 6, image 1 de 2 Shark IQ AV993 Wheels Replacement, Wheels: étape 6, image 2 de 2
    • Flip over the vacuum so that the bottom is facing upwards.
    • Remove the five 14 mm screws using a T20 Torx screwdriver.
  7. Shark IQ AV993 Wheels Replacement: étape 7, image 1 de 1
    • Pull upward on the wheel to remove the wheel housing.
    • Carefully remove this as there is a clip connecting to the wheel.
    • Press the tab on the clip and slide the wires out of the housing.
    • Repeat this step and the previous step for the other wheel assembly.
Marc Farah
Membre depuis le 10/26/22
94 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 3-3, Botvin Fall 2022 Membre de l'équipe UMass Dartmouth, Team 3-3, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 217
