Aller au contenu principal
Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
Ce dont vous avez besoin
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: étape 1, image 1 de 2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: étape 1, image 2 de 2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: étape 2, image 1 de 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: étape 2, image 2 de 3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: étape 2, image 3 de 3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: étape 3, image 1 de 1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
2 autres ont terminé cette réparation.
Pièces jointes
Nadir Abdusemed
Membre depuis le 10/12/21
124 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 11-5, Grodsky Fall 2021 Membre de l'équipe CSU Los Angeles, Team 11-5, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G5
1 membre
1 tutoriel rédigé
Un commentaire
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 37
30 derniers jours : 128
Total : 3,855
