Aller au contenu principal
Shark Navigator Lift-Away Zero-M Power Switch Replacement
Ce dont vous avez besoin
  1. Shark Navigator Lift-Away Zero-M Power Switch Replacement, Power Switch: étape 1, image 1 de 2 Shark Navigator Lift-Away Zero-M Power Switch Replacement, Power Switch: étape 1, image 2 de 2
    • Depress the dust cup release button and remove the dust cup.
  2. Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 2, image 1 de 2 Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 2, image 2 de 2
    • Use a Torx TR6 screwdriver to remove the seven 18 mm screws from the frame of the vacuum.
  3. Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 3, image 1 de 2 Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 3, image 2 de 2
    • Grab the front of the vacuum frame and lift the wand assembly to remove it.
    • This will reveal the underside of the switch.
  4. Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 4, image 1 de 2 Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 4, image 2 de 2
    • Use tweezers or your fingers to disconnect the power switch connectors.
    • Each of the wires has a release tab at the bottom of the metal portion. Be sure to depress it before pulling to avoid damage.
  5. Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 5, image 1 de 3 Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 5, image 2 de 3 Shark Navigator Lift-Away Zero-M Power Switch Replacement: étape 5, image 3 de 3
    • Push the switch out of its housing from the underside.
    • Remove the switch.
Chris Collins
Membre depuis le 02/05/24
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 78
