Introduction
Ce guide vous expliquera comment remplacer la brosse rotative.
Ce dont vous avez besoin
Faites sortir les deux petites roues situées sur le devant en bas du compartiment du rouleau-brosse.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
42 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
35 commentaires
Very helpful and easy. Thank you.
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
