Aller au contenu principal
Shark Rocket Zero-M Belt Replacement
Ce dont vous avez besoin
  1. Shark Rocket Zero-M Belt Replacement, Belt: étape 1, image 1 de 1
    • Flip the vacuum on its right side.
  2. Shark Rocket Zero-M Belt Replacement: étape 2, image 1 de 3 Shark Rocket Zero-M Belt Replacement: étape 2, image 2 de 3 Shark Rocket Zero-M Belt Replacement: étape 2, image 3 de 3
    • Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
  3. Shark Rocket Zero-M Belt Replacement: étape 3, image 1 de 3 Shark Rocket Zero-M Belt Replacement: étape 3, image 2 de 3 Shark Rocket Zero-M Belt Replacement: étape 3, image 3 de 3
    • Turn the vacuum face down.
  4. Shark Rocket Zero-M Belt Replacement: étape 4, image 1 de 3 Shark Rocket Zero-M Belt Replacement: étape 4, image 2 de 3 Shark Rocket Zero-M Belt Replacement: étape 4, image 3 de 3
    • Use a spudger to pry the side of the vacuum open.
  5. Shark Rocket Zero-M Belt Replacement: étape 5, image 1 de 3 Shark Rocket Zero-M Belt Replacement: étape 5, image 2 de 3 Shark Rocket Zero-M Belt Replacement: étape 5, image 3 de 3
    • Use a spudger to pry the old belt away from the two gears.
    • The new belt will be tight and difficult to put back on. In order to reinstall, place the belt on the brushroll, then rotate the brushroll a couple rotations to make sure the belt is aligned correctly.
  6. Shark Rocket Zero-M Belt Replacement: étape 6, image 1 de 1
    • Repeat on the other side of the vacuum.
Nadia Martinez
Membre depuis le 04/15/21
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team S1-G4, Harris Spring 2021 Membre de l'équipe CSU Los Angeles, Team S1-G4, Harris Spring 2021
CSULA-HARRIS-S21S1G4
1 membre
1 tutoriel rédigé
Un commentaire
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
jason kennedy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 61
Total : 3,287
