Introduction
When the vacuum is failing to pick up dirt or spitting it back out, check the roller brush for damage. Multiple missing or broken bristles as well as a broken or cracked brush can fail to pick up dirt .
Ce dont vous avez besoin
Pull the handle while pressing the lift away button to remove the body of the vacuum.
5 autres ont terminé cette réparation.
6 commentaires
Good day, I have a rotator lift away NV500 my belt indicator light stopped working but I was still getting suction. I replaced the filters and hep filters,as well as changed the belt. I cleaned off the dust and then carefully put the vacuum back to gather. I went to plug it in all worked until I pushed the roller brush indicator on and it still did not work. What else could it be? Any suggestions.
I await your reply
Angela
Same here what would be wrong with it
Great instructions - the 11mm hidden screws plus one more were tricky to find. Thanks so much for the great graphics and very clear disassembly steps; I almost gave up and was going to take it to a dealer for a costly repair fee. Thanks again!
Great directions and guidance - many thanks!
