Aller au contenu principal
Shark Vacuum Pet Hair Power Brush Roller Replacement
Ce dont vous avez besoin
  1. Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: étape 1, image 1 de 2 Shark Vacuum Pet Hair Power Brush Roller Replacement, About the unit: étape 1, image 2 de 2
    • This Shark model brush head consists of 7 parts: a base frame, a gear, a roller brush, two side screws, a plastic round band, and a top frame of the head.
    • Push the grey button on the back panel to open up the brush head.
  2. Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: étape 2, image 1 de 3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: étape 2, image 2 de 3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Disassembly: étape 2, image 3 de 3
    • Take the purple gear, belt, and brush out of the body.
    • Save the belt as this is needed to make the unit operate.
  3. Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: étape 3, image 1 de 3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: étape 3, image 2 de 3 Shark Vacuum Pet Hair Power Brush Roller Replacement, Replacing the brush: étape 3, image 3 de 3
    • Pull out the side screws from the right and left side of the old roller brush and put them on the replacement roller brush.
8 autres ont terminé cette réparation.
Roshni Sachar
Membre depuis le 03/19/16
298 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-23, Lauer Spring 2016 Membre de l'équipe Michigan Tech, Team 1-23, Lauer Spring 2016
MTU-LAUER-S16S1G23
1 membre
1 tutoriel rédigé
15 commentaires
Cat hair will jam up in the small gap between the gear and the bushing on the turbine and will cause enough friction to stop the turbine. I used a needle to dig out the hair and it solved the problem.
hvabrams - Réponse
Great tip! It works now! TY!
Wendy Dean -
perfect solution, could find the problem
Pat Gustafson -
Thank you so much for posting this helpful advice… it was the perfect solution to fix exactly what was happening to stop the turbine on the brush accessory for my Shark vacuum. Because I couldn’t find info anywhere else, especially - and frustratingly - the manufacturer’s site, I almost ended up purchasing a replacement part. I so appreciate your suggestion here!
Elizabeth C Lewis -
very clear and concise. took me 5 minutes with your instructions - couldn’t find anything like this on the shark site.
tigersfoot - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 66
30 derniers jours : 311
Total : 45,710
