Aller au contenu principal
Shark Vertex Pro IZ682H Post-Motor Filter Replacement
Ce dont vous avez besoin
  1. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Battery: étape 1, image 1 de 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: étape 2, image 1 de 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: étape 3, image 1 de 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: étape 3, image 2 de 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: étape 4, image 1 de 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement: étape 4, image 2 de 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
  5. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: étape 5, image 1 de 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: étape 5, image 2 de 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: étape 5, image 3 de 3
    • You will find the post-motor filter in the device under where the dust cup was.
    • The post-motor filter can be easily removed now.
    • Clean the filter with soap and water.
    • Examine your filter for any damage, and if you find any you can buy a replacement on the Shark website.
Tyree Brooks
Membre depuis le 10/26/22
486 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Membre de l'équipe UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 68
Total : 1,077
