Introduction
The circuit board acts as the brains of the device and without it, the vacuum will not function. As a result, when dealing with the circuit board, be sure not to damage or scratch the surface, as it may damage components necessary for operation.
If you need to replace the circuit board of your Shark Wandvac Power Pet WV410, this guide will walk you through the steps. A faulty or unresponsive button may also warrant the need for such a replacement.
Ce dont vous avez besoin
Squeeze the tabs at the base of the handle to release the battery from the vacuum.
Use a Torx T3 screwdriver to remove the two screws that attach the dust cover to the vacuum.
Use a Torx T3 screwdriver to remove the single screw near the yellow dust cover slide-release button.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
First time using this site and I’m genuinely impressed.
