Aller au contenu principal
Sharp Aquos LC13B2UA Power Button Replacement
Ce dont vous avez besoin
  1. Sharp Aquos LC13B2UA Power Button Replacement, Stand: étape 1, image 1 de 2 Sharp Aquos LC13B2UA Power Button Replacement, Stand: étape 1, image 2 de 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Power Button Replacement: étape 2, image 1 de 2 Sharp Aquos LC13B2UA Power Button Replacement: étape 2, image 2 de 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Power Button Replacement, Back Case: étape 3, image 1 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: étape 3, image 2 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Back Case: étape 3, image 3 de 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Power Button Replacement: étape 4, image 1 de 2 Sharp Aquos LC13B2UA Power Button Replacement: étape 4, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Power Button Replacement: étape 5, image 1 de 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: étape 6, image 1 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: étape 6, image 2 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Motherboard: étape 6, image 3 de 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Power Button Replacement: étape 7, image 1 de 2 Sharp Aquos LC13B2UA Power Button Replacement: étape 7, image 2 de 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Power Button Replacement: étape 8, image 1 de 2 Sharp Aquos LC13B2UA Power Button Replacement: étape 8, image 2 de 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Power Button Replacement: étape 9, image 1 de 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Power Button Replacement, Power Button: étape 10, image 1 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: étape 10, image 2 de 3 Sharp Aquos LC13B2UA Power Button Replacement, Power Button: étape 10, image 3 de 3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
Robert Hobson
Membre depuis le 01/20/11
1 290 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 1-11, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 14
Total : 6,513
