Aller au contenu principal
Sharp EL-520X Loose Circuit Board Wire Fix
Ce dont vous avez besoin
  1. Sharp EL-520X Loose Circuit Board Wire Fix, Sharp EL-520X Loose Circuit Board Wire Fix: étape 1, image 1 de 1
    • Remove the single screw from the battery door using a Phillips #00 screwdriver.
    • Remove the battery door.
  2. Sharp EL-520X Loose Circuit Board Wire Fix: étape 2, image 1 de 2 Sharp EL-520X Loose Circuit Board Wire Fix: étape 2, image 2 de 2
    • Remove two screws inside the battery compartment using a Phillips #00 screwdriver.
    • Remove the four screws in the corners of the calculator using a Phillips #00 screwdriver.
  3. Sharp EL-520X Loose Circuit Board Wire Fix: étape 3, image 1 de 1
    • Flip the calculator to the front panel and use an opening pick to pry around the sides of the panel to pop it open.
    • Gently lay it open to reveal the circuit board inside.
  4. Sharp EL-520X Loose Circuit Board Wire Fix: étape 4, image 1 de 1
    • Using a de-soldering braid, remove the old solder on the area where the loose solar cell wire will be fixed to.
    • Be careful not to damage your circuit board with the hot soldering iron. Do not place the soldering iron tip near the circuit board for long periods of time.
    • Use a soldering iron rest, so you don't directly place the hot soldering iron on your working surfaces which may lead to damages.
  5. Sharp EL-520X Loose Circuit Board Wire Fix: étape 5, image 1 de 1
    • Place the loose solar cell wire on to the de-soldered area of the circuit board and apply new solder on to that area.
  6. Sharp EL-520X Loose Circuit Board Wire Fix: étape 6, image 1 de 1
    • Carefully place the back panel back on to the calculator.
  7. Sharp EL-520X Loose Circuit Board Wire Fix: étape 7, image 1 de 3 Sharp EL-520X Loose Circuit Board Wire Fix: étape 7, image 2 de 3 Sharp EL-520X Loose Circuit Board Wire Fix: étape 7, image 3 de 3
    • Secure the back panel with the screws you removed in Steps 1 and 2 using a Phillips #00 screwdriver.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Mohamad Mohamad
Membre depuis le 01/18/21
436 Réputation
3 tutoriels rédigés
Équipe
York University, Team M-6, Allen Summer 2023 Membre de l'équipe York University, Team M-6, Allen Summer 2023
YORK-ALLEN-SU23SMG6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 33
Total : 340
