Introduction
You'll be replacing the keyboard component of the Sharp PC - MM20!
Ce dont vous avez besoin
First, remove the battery from your laptop and make sure it is powered down.
Outil utilisé dans cette étape :Tweezers$4.99
Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
Also, remove the flat cable from the track pad to the laptop.
