Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sharper Image Razor Scooter (Wheel-e Series) Teardown
Ce dont vous avez besoin
  1. Sharper Image Razor Scooter (Wheel-e Series) Teardown, Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 1, image 1 de 1
    • In order to conduct this teardown you will need (depicted from left to right):
    • 1 Hammer
    • 1 Pair of Channel Lock Pliers
    • 1 Flathead Screwdriver (for prying)
    • 1 Pair of Needlenose Pliers
    • 1 Metric Allen Key Set
    • 1 Pair of Snapring Pliers
    Demander à FixBot
    Ajouter un commentaire
  2. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 2, image 1 de 1
    • Start by pressing the lock lever with your thumb and unfold the scooter into riding position.
    Demander à FixBot
  3. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 3, image 1 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 3, image 2 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 3, image 3 de 3
    • Take the top of the scooter and open the handlebar lock to expose the small screw underneath. (Picture 1)
    • Using a 3mm allen key unscrew the single retaining screw. (Picture 2)
    • Once the screw is removed the clip tightening screw can be removed by hand freeing the whole retaining clip. (Picture 3)
    Demander à FixBot
  4. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 4, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 4, image 2 de 2
    • Now that the retaining clip has been freed, slide it off towards the handlebars. (Picture 1)
    • Once the retaining clip is removed the handlegrip "T" will now easily slide out of the scooter base. (Picture 2)
    Demander à FixBot
  5. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 5, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 5, image 2 de 2
    • Moving down the remaining scooter shaft, use a 5mm allen key to remove the lower retaining ring. (Picture 1)
    • Now remove the remaining scooter shaft by unscrewing it from the the wheel and axle. (Picture 2)
    • Hint: Hold the front wheel while unscrewing the shaft to prevent the axle from spinning.
    Demander à FixBot
  6. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 6, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 6, image 2 de 2
    • Using your hand unscrew the first nut on the axle. (Picture 1)
    • Note: This is the jam-nut used to stop the axle from falling apart.
    • Now using the Channel Lock Pliers remove the axle retaining nut. (Picture 2)
    • Hint: You may have to hold the front wheel to prevent the whole assembly from rotating.
    Demander à FixBot
  7. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 7, image 1 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 7, image 2 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 7, image 3 de 3
    • The axle is now able to be slid out. (Picture 1 & 2)
    • Note: this piece could be covered in grease.
    • Now carefully remove the bearing sitting inside of the axle housing. (Picture 3)
    Demander à FixBot
  8. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 8, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 8, image 2 de 2
    • There will also be a bearing on the axle itself which can also be easily slid off. (Picture 1)
    • Now that the axle is free the front wheel can easily be removed using two 5mm allen keys. (Picture 2)
    • Hint: If you only have one 5mm allen key, the 5mm allen key and the pair of needle nose pliers can be used instead of two allen keys.
    Demander à FixBot
  9. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 9, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 9, image 2 de 2
    • The rear wheel assembly can now be removed using a 5mm allen key. Use the same process as that to remove the front wheel in Step 8. (Picture 1)
    • The one screw will disconnect the rear wheel and the wheel-e bar from the scooter frame. (Picture 2)
    Demander à FixBot
  10. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 10, image 1 de 2 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 10, image 2 de 2
    • The brake mechanism is attached to the base by a steel pin. This pin is difficult to remove, but would be possible with a large press. (Picture 1)
    • Caution: It is our recommendation that you do not attempt to remove this pin unless absolutely necessary. It will be very difficult to get back in place.
    • A torsion spring controls the actuation of the brake. (Picture 2)
    Demander à FixBot
  11. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 11, image 1 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 11, image 2 de 3 Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 11, image 3 de 3
    • Remove all six snap rings from the pivoting assembly. The process for using snap ring pliers is shown in Pictures 1-3.
    • Hint: Three snap rings are shown in Picture 1. The remaining three are on the other side in the same location.
    • Note: It is recomended to wear eye protection during this step since snap rings have a tendency to spring all over the place.
    Demander à FixBot
  12. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 12, image 1 de 1
    • Remove the black plastic piece indicated in the picture.
    • Hint: Use the screwdriver to get under one of the flanges. It should come off very easily.
    Demander à FixBot
  13. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 13, image 1 de 1
    • Pry the black plastic piece from the front of the scooter. This will take some work, but the piece will come off intact.
    • Note: This will allow you to see the inner workings of the pivoting mechanism.
    Demander à FixBot
  14. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 14, image 1 de 1
    • Remove the spring from the inner workings of the pivoting mechanism with the needle nose piers.
    • To remove the spring: First, pull on the visible hook, then push the hook back into the mechanism to remove the tension on the second hook.
    • Leave the spring in the mechanism for now. It will be retrieved once the pins are removed.
    Demander à FixBot
  15. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 15, image 1 de 1
    • Remove all three pins from the pivoting assembly.
    • Hint: We found it helpful to use the long bolt from the back wheel to hammer out these pins which were difficult to get out. (Picture 1)
    • Note: Once complete, the remaining pieces should fall out as the pivoting piece is removed from the base.
    Demander à FixBot
  16. Sharper Image Razor Scooter (Wheel-e Series) Teardown: étape 16, image 1 de 1
    • The teardown is now complete.
    Demander à FixBot
3 autres ont terminé cette réparation.
Mark
Membre depuis le 03/31/13
221 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
aloha ue why not be following the guide introduction in the information is razor scooter not unable to work our ineeding be a chagering please I what to know to me I getting fasteration is my elecrtrical toys bluerazor please has a battery bottom.
michael sears - Réponse Partager
Mark - would you be able to draw a simple diagram that shows how the springs and levers are oriented to enable the folding mechanism to work properly? I stupidly did not take a close look before tearing down my scooter.
Alex Gurzau - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 73
Total : 15,635
