Introduction
Speakers rely on precisely placed components to convert electronic signals into sound waves. Touching the speaker by pushing or pulling can cause the speaker components to deform. As a result, the speaker will no longer produce an accurate sound. Replacing the speaker is the best repair for speaker damage.
Unplug the speaker before doing any work on it.
  • Unplug the speaker before doing any work on it.
  • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
Ajouter un commentaire
Remove the back panel.
  • Remove the back panel.
  • Remove the snap cable that connects the speaker to the circuit board.
  • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
  • Use a plastic opening tool or spudger to pry off the front panel.
  • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
  • Remove the defective speaker.
Linda Freund
Membre depuis le 06/08/2017
205 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 88
