Introduction
ShredLights rechargeable RGB LED lights mount to your skateboard or longboard to be visible at night. The SL-FX model, the predecessor to the SL-FX+, is not Bluetooth compatible.
This guide shows how to reconnect the battery wire to the light. In this case the battery adhesive failed, after which the board vibrations caused the wires to fatigue and break off at the PCB interface. This repair requires basic soldering skills.
Below are some tutorials:
Ce dont vous avez besoin
Using a Phillips #2 screwdriver, remove the four corner screws.
Remove the rear case half.
