Introduction
If the boiler is clogged (from lime) or the heater stops working, then it must be replaced. This is shown here.
Note: the pictures are from the almost identical Melitta Caffeo. The only major difference is that the thermoblock is installed rotated by 90 °.
Ce dont vous avez besoin
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
Follow the steps in reverse order to reassemble your device
Merci à ces traducteurs :
100%
oldturkey03 nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
