Introduction
If the coffee doesn´t flow right into your cup, but in the drawer the drainage valve might be broken. You can replace the gaskets in the valve or simply the whole valve.
Ce dont vous avez besoin
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
The drainage valve is exposed.
Remove the spring on the lower end of the valve.
Lift the upper gray part of the valve. Push the lower part of the valve a little bit downwards und lift it out.
To reassemble your device, follow the steps in reverse order.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
VauWeh nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
5 commentaires
Hi, will be a issue if i will cancel the valve by removing the cam and setting up the position as water will go straight away to brew?
Do I understand it right: you want to use the surpresso without a drainage valve? I think it's impossible. Swap it, it's rather cheap.
VauWeh -
Hat sehr gut geklappt! Hatte kurz Streit mit der Brühgruppe, aber ich habe dann gewonnen. Danke, sehr hilfreiche Anleitung. Manchmal muss man sich bloß trauen...
Freut mich. Genau dafür ist iFixit da.
VauWeh -
