Aller au contenu principal
Signode BXT3-16 Strapping Combo Tool Spring Replacement
Ce dont vous avez besoin
  1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: étape 1, image 1 de 1
    • Before dismantling the strapping gun, ensure the power source / battery is removed.
  2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 2, image 1 de 1
    • Turn the strapping gun upside down.
    • Place it on a flat surface to keep the strapping gun stable during repair.
    • There are four Torx T4 screws on the bottom of the tool.
  3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 3, image 1 de 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 3, image 2 de 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 3, image 3 de 3
    • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
    • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
    • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
  4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 4, image 1 de 1
    • Rotate the strapping gun to the opposite side.
    • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
  5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 5, image 1 de 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 5, image 2 de 2
    • Rotate the strapping tool to the original position, with the model number and name facing you.
    • Firmly pull the guard plate and the tool apart using both hands.
  6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 6, image 1 de 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 6, image 2 de 2
    • Use a metal spudger to lift the cutter.
    • Gently, push the spring out from the bottom of the base of the strapping gun.
  7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 7, image 1 de 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 7, image 2 de 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: étape 7, image 3 de 3
    • Rotate the machine to remove the spring gently by hand.
    • Remove the spring from the base of the strapping tool.
    • Replace with new spring by inserting it the same way it was removed.
2 autres ont terminé cette réparation.
Jainam Shah
Membre depuis le 02/01/24
160 Réputation
1 tutoriel rédigé
Équipe
York University, Team M-10, Allen Winter 2024 Membre de l'équipe York University, Team M-10, Allen Winter 2024
YORK-ALLEN-W24SMG10
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 26
Total : 124
