Aller au contenu principal
Sirius Stiletto 2 Scroll Wheel Replacement
Ce dont vous avez besoin
  1. Sirius Stiletto 2 Scroll Wheel Replacement, Battery: étape 1, image 1 de 1
    • From the back of the device, slide the back panel downwards to unlock the panel.
    • Lift the panel up, exposing the battery.
  2. Sirius Stiletto 2 Scroll Wheel Replacement: étape 2, image 1 de 2 Sirius Stiletto 2 Scroll Wheel Replacement: étape 2, image 2 de 2
    • Pinch the battery from both sides and lift the battery to remove it.
  3. Sirius Stiletto 2 Scroll Wheel Replacement, Front Cover: étape 3, image 1 de 1
    • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
  4. Sirius Stiletto 2 Scroll Wheel Replacement: étape 4, image 1 de 2 Sirius Stiletto 2 Scroll Wheel Replacement: étape 4, image 2 de 2
    • Start by using a plastic opening tool to loosen the front cover from the sides.
    • Work your way to the bottom of the cover then the top.
    • Carefully pry the front cover off.
  5. Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: étape 5, image 1 de 2 Sirius Stiletto 2 Scroll Wheel Replacement, Scroll Wheel: étape 5, image 2 de 2
    • Isolate the scroll wheel assembly
    • Gently pry the four metal tabs outwards, away from the scroll pad.
  6. Sirius Stiletto 2 Scroll Wheel Replacement: étape 6, image 1 de 1
    • Once the scroll pad has been released, be careful not to drop the center button. This may damage the spring.
Benjamin Her
Membre depuis le 01/21/15
555 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 6-6, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 296
