Introduction
Grip tape is an essential part of any skateboard. Grip tape provides the rider with an ample amount of grip on their skateboard, but grip tape wears out. This guide aims to teach a skateboarder with any amount of experience how to change the grip tape on their skateboard. Grip tape should be changed whenever your feet begin to slip on the board, or when tricks such as ollies or kickflips become more difficult due to lack of grip.
Ce dont vous avez besoin
Remove the bolts from your trucks using the 3/8 inch side of a skate tool and the included Phillips head screwdriver.
22.225mm Phillips head screw. (These should be standard for most skateboards)
Once the glue is warm on one end, peel the old grip tape off of the skateboard deck.
Peel the grip tape from one end of the board to the other.
Continue steps 2 and 3 down the length of the skateboard.
Take your time and heat all parts of the grip tape. This will help you remove the old grip tape in one large piece.
Before peeling the backing off of the new grip tape, line up the grip tape with the deck to make sure it is centered and the correct size.
Once you are satisfied by the centering of the grip tape, peel the backing off of the old grip tape.
Apply the grip tape from one end to the other.
Press out as much air as possible while applying the grip tape to avoid forming air bubbles under the grip tape.
After making sure trucks are secured properly, and your brand new grip tape is nice and grippy you are ready to ride!
Un commentaire
You can clean your grip tape on a skateboard or longboard with a portion of sanding belt cleaner or the entire block. Holding the sanding belt cleaner, begin section-by-section rubbing it on your grip tape from top to bottom in a straight line. But pay attention to the locations of the bolts. Gently wipe these areas down.
